Knippex side cutters, slotted and phillips screwdrivers, flat file, half round file, needle nose round file, pliers,needlenose pliers, 3x 20mm and 3x 25 mm holesaws+ 2 each arbours for them, a pack of 6mm HSS steel drill bits,couple of 10mm HSS steel Drillbits, a pack of Bosch 12mm SDS Drill bits (200 mm and 300 mm long) 2 x 25mm Bosch SDS masonry bits,couple of 6mm Bosch masonry bits for doing fixings, a pack of wood and a pack of metal Bosch jigsaw blades, small non insulated screwdrivers for small items on low voltage, along with CK and Irazola terminal screwdrivers, also a few sets ear plugs, some blue shoe/boot covers (saves being chased from a classy office building) a good set of safety glasses and a set of safety goggles, a good set of gland pliers (glandies, handy for bushes) a pyro stripper, a good co-axial stripper, a set of wire strippers, a good (about 60 pounds) terminal crimp tool, a voltage tester and a Fluke Volt alert voltage detector pen.....add to that an Estwing hammer, a 110v Bosch SDS Drill, 24 Volt Hilti cordless drill, plasterers compact light x 3, a handy trans branded easy carry single socket 110v site portable transformer (1,5kva) which has a shoulder carry strap, a bush key , a Podger (anchor setting tool- for driving in 12mm Anchors for screwed rod) a 110v Bosch angle grinder and a cheapo heat gun for heat shrink, good bahco hacksaw and either Bahco or Ultra Brand Bi-hard cobalt blades(blue and gold coloured) a sandvik/bahco toolbox wood saw, a pad saw for awkward plasterboard....and thats your tool kit sorted.....if you are 100% self employed then 2 x tap and die sets, 1 made up for 20mm and 1 made up for 25 mm, a couple of spare threading cutters of 20mm and 25mm, a pipe bender, tin of fire alarm tester spray smoke,makita chopsaw, fire extinguisher and a packet of scafftag labels for your work site...
A mini Maglite AA torch
A good small notepad
A fine black marker pen
A wide black marker pen
and if you can find one, a fisher spacepen, its pushing the boat out a little bit but they write on everything, concrete floor, wet paper, steel beam (painted or unpainted) brick, cable jacket, even the Galvi conduit and end boxes...
sorted.
