X
xraytek
Hi guys,
I have no experience with analogue outputs on PLC's, so was hoping someone can confirm or correct the following requirement:
I have a 0-10v scaled input going into my PLC and want that input to be duplicated on one of the analogue outputs.
Is it just a simple case of using MOV-W (move word) with AIW0 going in and AQW0 going out, or do I have to move the word to a memory location and then read from that, or something else completely different?
I have had a look in the manual regarding analogue I/O and can see how you can provide set outputs but not variable ones based on an input.
Thanks in advance.
Thanks in advance.
