Morning All, its a lovely day, hopefully I won't have to get in any lofts on a day like today.
Just a quick one regarding economy 7,
Where the meter provides two outputs, during off peak hours, what happens to the (main board) as in the general daytime DB, does this also switch over or does it just constantly run at the higher rate even through the night?
The reason I ask is I've been doing some communal work at a block of flats and several of the tenants have approached me asking about their hot water complaining that there setup doesn't supply them with sufficient hot water and that it's also costing them a fortune,
Setup is dual elements controlled by horstmann timeclocks with boost facility. To get hot water none of them are using the timer, just the boost setting. Some off them have dual tariff meters but with no teleswitch and others have newer meters with two outputs but no secondary boards.
My suspicion is that they're all running at peak rates constantly that's why it's costing them a fortune.
