L
LlandrilloSpark
Did an eicr today on a loft conversion wired by an unregistered spark, Eicr was requested by LABC once they realised they were not going to get the paperwork they wanted of this guy.
What we have here is the head guy at my LABC knowing who this guy is and saying "don't matter, your eicr tells us it's safe"
Thus guy blatantly not notifying and nothing is done to stop him
I went to a job today not knowing what it was as the guy wouldn't explain on the phone. Got there and it was to certify a job that had been done by a friend on an extension.When asked who did this the response was vague. Looked at CU and gas bonding wasn't up to scratch! So I kindly left and explaind I wouldn't certify as I had not done the work. Not worth the hassle I reckon and I believe they may struggle to get one. Sparkys should be used a moral of the story!
We if thats the case maybe all us DIs who are part of the scams should not renew our membership and instead just issue a EICR instEad if a EIC
It's a common misconception that it is the responsibility of the installing electrician to make notification.
It is in fact the person who orders the work or ultimately the house holder who is responsible for making notification.
As such, as long as the electrician is not being pretending to be 'Part P' registered, they are doing nothing wrong, and there is nothing the LABC can do about it.
If the electrician is pretending to be 'Part P' registered, there is still nothing the LABC can do about it.
It would be a matter for Trading Standards.
that is interesting info that i wasnt aware off - where can it be taken from for future reference?
I had a guy in Fenham do the same. Clearly wired himself. 4MM shower on 40a fuse and diagonal chases in the walls for wall lights. Wanted a db fitting but nothing connecting. But with cert..
I politely declined
well what you do...is find out who this guys `superior` is.....come on, dont you know theres lots of `official` lookin (and sometimes soundin off) hitlers around these days.....and usually at local government level.........so, what you do is find out who really is in charge there.....and just give them the opportunity to justify themselves (the office, the desk, the salary)......
So what's stopping us from issuing a EICR limited to cover the new work building control get a legit cert and no scam provider is involved
- - - Updated - - -
- - - Updated - - -
So what do people think about the April 2013 changes then when a non-registered or DIY'er will come to an approved to get work signed off and cut out direct contact with LABC?
Lets put it another way. Without spending several chargeable hours conducting your own thorough inspection and test procedure are you going to be prepared to put your name to a legal document which says everything is fine with an installation.
Trev, is that not what we did on PIR and now on EICR?, putting out name & reputation against a document ? @ the end of the day the judgment is ours, we have the power, if in any slight doubt at all...it's a fail
On an EICR it's an opinion though and you have the provision to say "this does not comply". On an EIC you are saying it complies.
I understand what you're getting at though
Are these changes defiantly goin ahead then? I knew they were being discussed as an option
they need to uturn and trust their sparks after all they paying millions to train them up..
- - - Updated - - -
also up to clients/customer to do homework in who they employ
Another example of why us legit guys are throwing money down the pan
LlandrilloSpark,
i=p/u,
