Another induction motor question | on ElectriciansForums
Discuss Another induction motor question in the UK Electrical Forum area at ElectriciansForums.net
here
which factors might affect the slip and what losses may be incurred by the motor ?
Cannot find much about this, i know that the load indirectly affects slip due to the rotor speed changing, more load is more slip
Any assistance is appreciated, thank you
If any websites is found in referance to this question that will be great, thank you
Synchronous speed is the rotating magnetic field and rated speed is the speed of the shaft. The rated speed will always lag the synchronous speed as it tries to keep up due to resistance against the shaft from its own weight and also the load placed on it. The difference is known as slip.
Do a Google search for" Liii instrumentation". A document by Dr Tony .... Something:) will come up. Download it and then read up on the motor section. It is written in Johnny age 5 language which judging by your previous outburst is ideal for you.
A hint: in order for currents to be induced in the rotor there must be relative motion - slip - between the rotating stator field and the windings of the rotor. There is then an electromagnetic interaction between the stator currents/field and the rotor currents/field which from Fleming's left hand rule produces a force/torque acting on the rotor windings (and an equal force of reaction on the stator coils). Then apply Newton's Laws of motion.
@ spark40.youpost during working hours when most members are out earning the necessary and get peeved when nobody replies within 3 hours. PRATT !
thank you for this, I was just confused abou the factors, i've grasped an understanding on what slip is, i have found the answers after doing intense research was only wondering if like minded people like yourselves could help a fellow brother out.
I've noticed the main factors is:
Load
Rotor resistance
Efficency
anymore will be appreciated
thx
Reply to Another induction motor question in the UK Electrical Forum area at ElectriciansForums.net
Hi James, At the inverter end the multi strand is ferruled and torqued in the terminal and at the motor end they are the “wago type” push fitting...
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
