Planning a ground mount system using the Console buckets (plastic). What happens about earthing the array if I use a transformer less inverter.
My thinking is do nothing, all panels are class II, not electrically connected except for the dc connections.
try a transformer inverter , easy earthing and no need for rcd , i have supplied many for ground arrays
eg eltek theia HE-t ip65 with webserver record effciency over 97% 4kwp unit is 16amp per phase
HF transformer universal inverter suitable for mono/poly , sanyo hybrid , thin film CDTE/CIGS/A-Si
in stock if required
Dorset
Another TL (transformer less) permutation
Thread Tags
yellowvanman,
daytona600,
