answer 2 questions | on ElectriciansForums
Discuss answer 2 questions in the UK Electrical Forum area at ElectriciansForums.net
United Kingdom
does anyone know how do do i Draw a circuit that will convert a galvanometer with a full-scale deflection (f.s.d.) of 1mA and internal resistance of 20Ω into an instrument capable of measuring up to 1A.
and another circuit to convert the same galvanometer to read 10 volts f.s.d.
thanks
so you want 1mA through the meter, so to measure 1A fsd, you need 999mA through a parallel shunt. your meter is 20 ohms, use ohms law to determine the value of your shunt resistance, but due to the tolerances of resistors, you'll never get accuracy.
Reply to answer 2 questions in the UK Electrical Forum area at ElectriciansForums.net
Thank you for getting in touch! Looking forward to use your services in the future! :)
I can imagine it just disappearing (loudly) under short circuit conditions, then the resulting blast/plasma etc. casing the busbars to flash over...
This potential client seems to be making progress in terms of being interested in proper chargers and answering my query questions. I have also...
