Ok no problem.....I've worked for a DNO and I can see what the OP hasn't or understands what is involved.Yes. You have to request access to the DIY forum from a mod. As you're not a practising spark they may not let you in!
Pros and cons. Never bother personally, but I can see both your points (so it can't be pointless).:smile5:
So it could be pointless then, not trying to sway you in anyway.
But I take Murdoch's point on board also!
Access given.hi, I was going to answer, help a OPs question which had been redirected to the DIY section but i'm unable to as denied access. Is this right?
Access given.I wouldn't mind access my self actually as I've seen quite a few I could give sensible answers to, I acknowledge it's a DIY forum and understand what sort of advice is to be given and limitations as to people's abilities, and not to suggest anything that's dangerous to the unskilled.
Access not givenyou wont get me in there.
Don't feel daft Dave, if you want access just ask the mod's, then you can ask questions and we will answer them for you![]()
Access given.
Access given.
Access not given![]()
How do you intend to terminate the ends?
Can I use flex to wire an lighting circuit?, please don't say yes.!!!!
Go on then, Marvo. I'll go with Murdoch, if you let me.
KindaIs this some sort of test ? :biggrin:
NO NoooooooooooooooooooooooooooooooooooooooooooooooooooooooYeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeessssssssssssssssssssssssssssssssssssssssssssssssss
Access given.
Anyone can have access to the DIY section but it's just not everybody's thing. The only thing we require is an understanding the posts must be constructive without being abrasive or belittling regardless of how stupid the question may seem. The DIY area is best suited to those that have the self control to walk away from threads they find annoying.
I'm trying to set it up so that when Glen's latest holiday is over the only forum he has full access to is the DIY[/B]
So when are you granting Glennspark access then Marvo
Kinda
I was referring to the light cct in flex question.
I'm trying to set it up so that when Glen's latest holiday is over the only forum he has full access to is the DIY![]()
Awww c'mon, your just being old fashioned. You know it would be better in flex because the CSA of the CPC is the same as the live and neutral so there's some added safety for a start. There's tons of other good reasons to use flex as wellNo terms on end, because I would not use flex. Full stop.
Awww c'mon, your just being old fashioned. You know it would be better in flex because the CSA of the CPC is the same as the live and neutral so there's some added safety for a start. There's tons of other good reasons to use flex as well![]()
Dave what's your issue with flex mate, just curious, I like flex and it as it's place.
Glen, just old school mate not for me on domestic installs.
I am with you on the domestic side mate, but it's popular in commercial/industrial
Not a pointless section IMHO
It keeps numptie DIYers in a a place where limited people can help them - and some just want constructive input, into situations, rather than a kit list of parts to do us out of work.
They won't let me in so I can't help the DIYers. :reddevil:
