SWMBO was returning from work one night last week in her S reg. VW Polo when (I quote) "it was like the battery n everything died, the clock reset and battery light came on". Then she drove home OK.
So I go out a couple of days later, check battery connections, looking good n clean. Yet to find where the earth connects to the body though! (Oh for the good old days when you could stand in the engine compartment and shelter under the bonnet to do stuff!!). Alternator has two small leads (dash indication?) and a larger cable which I suspect is the output/charge cable. That's a bit rusty and has some green corrosion (verdigris) on it.
Has anyone come across anything like this before and has any pointers as to what to look for? Just got a new Haynes as the old one is on a bench beside the A1, so I can delve a bit deeper.
I had something similar happen to me many years ago in an old Beetle when all the power just disappeared from the electrical system. Mind you, that was when a lightning strike hit the ground less than 25yds away! To say I shat me pants would be an understatement!!
TIA for any help.
TIA for any help.
