any body encounter this? | on ElectriciansForums
Discuss any body encounter this? in the Australia area at ElectriciansForums.net
lurch
I have been asked to do a consumer unit swap out, but I have not encountered this scenario before. Take a alook at these photos', and if anybody has any answers i would appreciate some pointers. . . . thx in advance
  • [ElectriciansForums.net] any body encounter this?
wouldn't be so bad if you needed a tool to access them but on the ones i've seen you don't just open them up and your in. good old wylex.
on a seperate note i've seen these with what looks like an earth stud on the bottom of the enclosure where the incomer is glanded, i tested it out of interest and it was a good Ze, anyone know if this would be the earth that was intended for use? i know that the earth bar is screwed to the enclosure so i would assume so. fitted a rod anyway but just curious.
Yep. Working on one today. Rewire but that box is inside the property (3 bed house) All existing circuits wire via steel conduit in wall and I’ve got the option to fit a dual RCD board above the meter/CU box so no real issues. Going to drop new circuits through the ceiling and into the board via the back entry knock outs. The only issue I have is getting meter tails into the new board. Considering re-using one 25mm steel conduit drop coming into the meter cabinet to pull new tails through to ceiling void.
Reply to any body encounter this? in the Australia area at ElectriciansForums.net
Hi sparks, this has probably been asked on here before but I couldn't find an answer using the search function. About to start my 2346...
I know it was a few years ago when LED was mor in its infancy but we looked at a job that had designer flo light fittings in a big bar. The...
