A
angellonewolf
any help on this would be great info I can give went to other half's parents house as they called to say they got a problem with there lighting circuit when mcb is switched on the power is on for a few/10 minutes and the mcb trips again
they had the consumer unit replaced 6/9 years ago its a split phase rcd one side main switch for the 2 6amp mcbs one is the lighting circuit I do not know what the other is yet
there is first I need to test the mcb ? as I there is 2 6 amp I can just cheak its not the faulty mcb
they have a few variable lighting switches and one ceiling fan and 2 2d energy saving fittings in the bathroom and kitchen I think I need to cheak as they are the first items I think might poss be causing a fault ?
any help would be great angel
