Any comments on Metrel PAT machines | on ElectriciansForums
Discuss Any comments on Metrel PAT machines in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
R
Roger WNPATS
I recently got Metrel MI3311 for small work. Begining to think Seaward 250 better.
Mains powered machine now needs replacing, so Metrel Beta or Supernova?
The supernova is good if kinda heavy n cumbersome in offices and the like most of the guys how use them do so on a hostess trolley type of arrangement .I like the seaward europa plus which gives u most of the advantages of the supernova but with the advanatge of being that bit easier to lug around by hand.To my knoledge its only bad point is that if your doing lots on 25A tests in rapid succession you need to let it cool down .
I have a spare europa if any one wants to buy it..ÂŁ300 inc barcode scanner and 9pin serial cable to connect to pc.
cheers 72-van
fife
I use a metrel beta its cumbersome and the cable entry isnt bestplaced causing cable to break Im trying to "aquire" a folding trolley for both Pat and when PIR testing as we do a lot of hotel work n 2circuits per room means your jumping around carryign stuff
[ElectriciansForums.net] Any comments on Metrel PAT machinesHey Guys -- this trolley is just great, Supernova fits perfectly and the whole thing folds flat. P.S. Great at cornering too !![ElectriciansForums.net] Any comments on Metrel PAT machines[ElectriciansForums.net] Any comments on Metrel PAT machines Trolley Dolly not included !
Its called a CLAX trolley you can find it on the web - should be about ÂŁ100
Reply to Any comments on Metrel PAT machines in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi Avo, Thanks for the reply. Think that's what i'll end up doing. The cal cert says everything is fine but i'll get a better picture once start...
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
