P
prgil74
just had quick look at ccu 12 way 100a/30ma hager isolator, problem seems to be that the rcd/isolator trips when all mcbs are on and when its wet, now turn off any two or three mcbs and the problem stops could under stand if one of the mcbs solved the problem but seems you can turn of any and it has to be two or more have done no testing as yet as it really was a quick look was thinking of neutral to earth fault but then it would still trip all the time ,faulty rcd any help would be great large house so could be in for the long hall if no ideas
