Any help ? | on ElectriciansForums
Discuss Any help ? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
L
lofty84
state measures to provide protection from live parts of terminations?
would you say this is asking me about protective equipotential bonding and automatic disconection of supply ie joing all exposed extraneous conductive parts within the istallation together
or am I headeing in the wrong direction ?
What is the statement in connection with?
I would say that it is likely to be looking at basic protection measures. You are heading toward fault protection
thanks alot.
list the four major classification of external influences with regard to utilisation of buildings
does
use of structure , environmental conditions, current demmand and overcurrent protection sound about right
From brb appendix 5 Classification of external influences table for utilisation of building pg 329
Capability of person
Contact of persons with earth potential
Conditions of evacuation in an emergency
Nature of processed or stored materials
No.
You need to read the question, then look up the external influences in Appendix 5 of BS7671.
There are 5 listed under Utilisation, but one doesn't have any codes, so I would assume that it is the other 4 that are required for the answer.
if I had to describe the relationship between the current carrying capacity of a conductor , the size of the conductor and the installation method where would I need to head in the BS7671
cheers
Reply to Any help ? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi I need help with understand supplementary bonding. I know RCD is additional protection and in the even of the fault at leakage of 30mA, it...
If you can see a piece of plastic entering from the ground then (as cliff said), it does not need main bonding. I think (not sure) this is reg...
