Any ideas what this is and if I can get a replacement? | on ElectriciansForums
Discuss Any ideas what this is and if I can get a replacement? in the UK Electrical Forum area at ElectriciansForums.net
Manchester
2 wires have broken off leaving 2 still connected.. it is in a switch for a table saw.
Upload the image directly to the thread: The most awesome images on the Internet - https://Upload the image directly to the thread.com/6ig2hSn
the 2 squiggles terminals are the input. that's from the supply side, either way round. the + and - need to be the correct way round. if that's any help.
Reply to Any ideas what this is and if I can get a replacement? in the UK Electrical Forum area at ElectriciansForums.net
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
The photo shows the other wires going to a switch mounted on the cover, does this switch have a label or do you know what it is used for? The...
