Any ideas? | on ElectriciansForums
Discuss Any ideas? in the UK Electrical Forum area at ElectriciansForums.net
K
kduck
I’m after a bit of help, I need a timer that can be programed to release a lid that just drop’s down at a given time.
The lid would just drop and hang there once the timer released it. But would also need something to hold the lid up until it’s released. The system would need to be 12v as well. Any ideas?
Does not need to work fast and would only work once a day from a timer. Would need to run it off a 12v battery as there is no power supply anywhere near it.
Was thinking about a car door solenoid main reason is they are cheap, the whole product must be under ÂŁ50....
If you are running a 12V battery system then you need to limit current usage and I would only recommend a solenoid that is instantaneous operation.
Have a metal plate and a permanent magnet, then have a solenoid that pushes the door away from the magnet at the programmed time, single strike, allowing the door to fall.
Reset by lifting the lid up to the magnet.
Try finding a timer like this one but in the UK (TLC do one for ÂŁ40) fish feeders, car accessories.
Reply to Any ideas? in the UK Electrical Forum area at ElectriciansForums.net
I doubt the terminals in those are suitable for 4mm, more likely designed for 1.5mm as they are limited to 16A. You could use the time switch to...
davesparks
Thanks all for the suggestions! Customer doesn't store anything else in the cupboard with the tank, not even towels or sheets. Heatrae stat is...
