dingledong
Customer has marble steps in the garden ,in each step the upright to the step has 2 holes with looped t+e coming out of them . The hole is 12ml ish . The lights going into the holes are extra low voltage and the transformer is feeding the twin and earth day .
Now the question
Any ideas with what I could join the fittings to the t+e ? I believe under the slabs is poured
concrete so shouldn't be wet but it might become damp ? So I need a small connection to join them waterproof if possible
A wagon with a insulation tape ? Or material covered in we 40 ?
I am sure you have better ideas
Now the question
Probably far too big :grin:
If you can't get the adhesive lined HST, self amalgamating tape is also a good option. Just make sure you wrap it under real tension, space permitting of course.
Feed cables through close fitting holes in mini potting box, crimp and fill with resin. Avoid soldering - tiniest amount of moisture penetrating will cause flux to attack joints over time.
any ideas ?
dingledong,
Lucien Nunes,
