any one have experience | on ElectriciansForums
Discuss any one have experience in the UK Electrical Forum area at ElectriciansForums.net
RIAU
anyone has problem-solving experience about autotransformer to start 1750HP motor, I had a problem with the system when I started the test with the main and start system 'the motor system control is working fine but moving from an initial condition to running the draw/starter unit can't work, no there is a reason I have in the protection of the system, I have a control wire and I do not find any other errors, but if I open the motor connection, the controls run normally. I have checked the motor isolation and the results are in good condition
Could it be the way the logic in the programming is written
Reply to any one have experience in the UK Electrical Forum area at ElectriciansForums.net
Hi James, At the inverter end the multi strand is ferruled and torqued in the terminal and at the motor end they are the “wago type” push fitting...
