Any one heard or use F & G MCB's | on ElectriciansForums
Discuss Any one heard or use F & G MCB's in the Australia area at ElectriciansForums.net
From memory they are cheap c..p and quite chunky with it , a bit like the new mem 3 shield gear !
Pretty sure we have some on the din rails up on the wall at our yard , if i get the chance i will have a look when i am back down in bucks tomorrow and try to post you a pic .
I've just been given an EICR thats has code 2 items reporting that a mix of MCB's are causing stress to the bus bar. Went to site look at doing remedial work and found it's an F&G 3 phase DB. What can these mob's be legitimately be replaced with? Someones used wile but they don't seem to sit right.
Reply to Any one heard or use F & G MCB's in the Australia area at ElectriciansForums.net
Its important to remember that a plug top fuse is just a rewireable fuse that's convenient to change and shouldn't be confused with a HRC fuse...
