Any recommendations for shallow, fire rated, insulation coverable, integrated downlights | on ElectriciansForums
Discuss Any recommendations for shallow, fire rated, insulation coverable, integrated downlights in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
As in the title.
I need downlights that can be covered in insulation, fire rated and integrated.
Preferably quite shallow as well!
I'm struggling a bit to meet all the above criteria :(.
Cheers guys.
JCC V50. 2" height and coverable.
or....
or....
Cheers Tel,
So I'm guessing they need a separate led driver? Also, can they be covered in insulation?
or....
Cheers again Tel.
Customer has now added another criteria!!!
They have to be dimmable!
I don't think the ones in your link are?
the JCC V50s are dimmable. and switchable either warm white or cool white.
I believe the enlite E8 are coverable too and come in a dimmable format.
I use KSR QR10 mostly which are coverable and dimmable but come with a separate driver, which is not coverable. Not usually a problem though.
JCC V50 as others have said (irritation on registering batch codes, though), or Knightsbridge/ML RW6 range (either warm white, cool white, switchable (via wall switch), or "dim to warm").
Have installed about 30-40 of these over the past couple of years and (touch wood) not had a callback yet.
CEF do Enlite slim fit LED units, the driver is separate and I'm not sure of fire rating but they have decent lumens.
As in the title.
Cheers guys.
Collingwood H2 Lites. (They're also dimmable.) Not sure how shallow you need though.
[automerge]1575272901[/automerge]
Oops. See Lee beat me to it.
Reply to Any recommendations for shallow, fire rated, insulation coverable, integrated downlights in the UK Electrical Forum area at ElectriciansForums.net
I personally have two Integral Evofire Recessed (low-glare) on trial at home outside the UK; just realized they were, however, made of steel. The...
  • Poll
Hi Folks, I'm looking for downlights that satisfy the following criteria: (1) white bezel; (2) fire-rated; (3) IP65 or above; (4) anti-glare...
