Any recommendations for workable pliable SWA | Page 2 | on ElectriciansForums
Discuss Any recommendations for workable pliable SWA in the UK Electrical Forum area at ElectriciansForums.net
Midlands
Any recommendations for workable pliable SWA that doesn't need butchering when trying bend and terminate.
That is odd.
Duct allows for cable replacement if needed, also gives a little more protection against the odd stone, etc., if badly back-filled. Also not likely to rust!
Aye, i was puzzled to be honest. Just black placcy conduit. Ducting is essential imo but conduit is just odd. I thought it might have been a one off that someone had gotten wrong, but every one of the 80 houses on the estate is like it.
It can help prevent tearing the outer sheaf when rough --- bodgers pull it through the wall without a care in the world.
Reply to Any recommendations for workable pliable SWA in the UK Electrical Forum area at ElectriciansForums.net
This EV 10/16mm 3 core ultra cable sounds good to run it in the front. I ran 3x CAT5 armoured cables at the back. The existing 10mm cable goes...
Just have a look for plug in power monitors. Much quicker and cheaper probably
