Hi all,
Anyone out there able to take on a new 4kW install in S. Devon (Totnes - Kingsbridge - Dartmouth area) before the deadline? I had someone lined up following a recommendation but he seems to have disappeared off the planet.
In detail I am looking for 16 x 240W (or conceivably 22 x 180W) panels, preferably with black frames to go with the slate roof. Ideally I would also like an SMA inverter but am prepared to consider any reputable make of inverter and panel. Ideal aspect as roof faces due South. In other respects should be an uncomplicated job with easy access inside and out.
PM me if you are able to help.
TIA, Chris.
TIA, Chris.
