In the flat i live in i have an extractor fan in the kitchen that is fed by a 1.0mm2 3core FT&E. The supply comes a fused connection unit off the RFC. The extractor has L SL N CPC. The switched live is terminated on the
load side of the FCU, as is the Neutral. The permanent live is terminated in the supply side of the FCU with the 2 RFC lines.
I have not seen it done like this before and am just curious if anyone else has. Obviously switching the FCU off does not isolate the fan from the Permanent Live.
Does the fact that the fan is a fixed load mean the permanent live only needs fault protection, as it is technically "protected" by the 32A Type B 60898?
The switched live is protected by the 5A fuse in the FCU.
