Any thoughts please.... flickering supply | on ElectriciansForums
Discuss Any thoughts please.... flickering supply in the Australia area at ElectriciansForums.net
sythai
Devon, United Kingdom
Evening all...
Customer has flickering lights and seems to get worst when airsource heat pump is fired up.
Have checked all connnections are tight, tails etc, all ok ?
Could it be the incoming supply maybe, it's at the end of the line and overhead or am I missing something ?
Sy
Well those heat pumps use a lot of juice, and as you are at the end of line, volt drop may be an issue.
Have you measured the voltage at the light fittings when the pump is running???
had similar problem with a client. fluorescent lights in his offices were flickering. turned out he was running on 205 volts. only solution was a new supply from new tranny at nearest pole. cost him a bomb
Hi sythai,
Have you checked the fuse at the head?......I've had a few of these where the fuse/contacts overheat and discolours and softens the contacts.....bad contact and inconsistent supply the result.It would be apparent under load as the fuse holder will get noticably warm.....apologies if this is in egg sucking territory.
Hi sythai,
ah- over here that's part of the supply
Can imagine they will try and deny all knowledge..... :(
Henleys, tails all good and tight that was my first thought loose neutral. Main fuse looked in good nick and wasn't getting warm, but might consider swapping for a new one which my kind friend at the DNO has given a few of (luckily someone has already cut the seals)
Chris.... yes eventually found out yesterday that couple of people down the lane also had probs. Wish I'd known this on Thursday evening before my 1.5 hour round trip through rush hour traffic, stress !! I just couldnt leave it, regular customer with young baby, right out in the sticks etc..... and I didnt get paid/charge for it, thats customer service for you :)
At the end of the day I would of still billed them.
I had a similar problem. What I did was made up a temp socket wired straight into supply. Put megger on volts setting in one socket and plugged kettle into other socket. Volts dropped big time.
DNO supply fault in the road.
Reply to Any thoughts please.... flickering supply in the Australia area at ElectriciansForums.net
Yes, they need to investigate. They have a duty of care to make sure that A, they give you an uninterrupted supply, and B, any faults don’t start...
300W is 300W regardless of the voltage. The lower the voltage, the higher the current, but same power consumption overall. You can clamp meter...
Try disconnecting the "central heating off" wire from terminal 2 and insulate it (eg Wago connector or choc block or similar) and tuck it out of...
Check with your DNO as they will have a few questions. in theory no technical obstacles but we are not quite there yet with a clear agreed process.
