Any tips for my am2??? | on ElectriciansForums
Discuss Any tips for my am2??? in the UK Electrical Forum area at ElectriciansForums.net
Do what is asked, follow instructions and diagrams. Proper safe isolation with all checks. Ask to isolate the installation. Keep key. Confirm it's ok to IR test. Remember sleeving on black SL or grey N. They will watch closely, if for no other reason than to make sure you work safely and no incident forms are required. I'm sure others will have more :)
Read the instructions properly and take them in. Always remember take the key out on safe isolation. Fault finding isn’t as difficult as you make it in your own head. I spent 20 minutes on the first one and if I hadn’t over complicated it it would of took me 2 minutes. There’s loads of time. Just get it right first time
Use the reading time they give you to read over the task in hand. Don't rush it and try jump into it. Use the time you have, there is plenty of it, and there is no extra prizes for finishing in half the time.
Follow the task instructions you get given for inspection and testing as it lists the things you must do and can help jog your memory if you forget something.
When you're isolating something with a switching arrangement in it, ensure you check the thing is isolated on all the possible combinations of switching.. you never know how it's been wired!
Be smart when fault finding. Don't spend too long on one as can move on and come back to it once you've worked through the others.
The multi choice is straightforward, you get given the books with all the answers. So use the contents and index pages to find what you need, if it asks for a definition, don't guess, just look it up.
Best of luck!
As above.
Read the spec carefully. Don't forget the bridge clip for the data cable in the dado. Keep the data pairs twisted all the way to the termination. No more than 10mm untwisted I was told at the AM2 prep day I was sent on.
These things will not be written in the spec.
Stay focused and use the time.
Good luck. :)
Reply to Any tips for my am2??? in the UK Electrical Forum area at ElectriciansForums.net
Yes that was me. If you change your mind give me a shout and I’ll sort something out for you 👍
Hi Lou thanks for this. I am an NICEIC contractor and kindly been given a grace period to complete my experienced worker L3 NVQ. Sitting my AM2E...
