Any whitegoods dabblers around tonight | on ElectriciansForums
Discuss Any whitegoods dabblers around tonight in the UK Electrical Forum area at ElectriciansForums.net
i=p/u
Northern Ireland
Have a washing machine blowing the fuse , so tested socket all ok.
then notice have short between L&N on plug top, so take off top of machine and disconnect out going of mains capacitor , and it still shorting .
Is that me found my fault , don't want to order part
can I bypass capacitor and still work?
if that is a capacitor across L and N terminals, bin it. then see if the dhort has gone. it's only a rfi suppressor. if your radio is tuned to radio 1, you'll not see any detriment.
Just out of interest,how did you identify this short,and what is its magnitude? Cheers fella
Reply to Any whitegoods dabblers around tonight in the UK Electrical Forum area at ElectriciansForums.net
Assuming you are a novice to electrics? As in no access to electrical equipment. Plug something in to the sockets that you know works else where...
Cbelectrics
C
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
