Been working in a old property. Wiring is getting on a bit but one of the breakers has failed. Not a major problem as the lights are split between numerous circuits and i can take an old one out of the now redundant and unused eco7 board that used to power the old lights in laundry/maids room.
Cant see any markings on them or when opened up cu front casing to see make/model etc as im trying work out type along lines of type b 60898 etc... to get a good look requires a bit of effort. It is located in grand hallway with very high ceilings about 5 feet above a door!
It is so high up on the wall it needs a tall step ladder to reach and im 6ft2!!... owner has to use a long cane or fishing rod if a breaker trips!
Trying to avoid a replacement and will be going for rcd socket outlets next week when i do some additions.
Apologies for poor angle but given height i struggled to reach it fully on this visit.
Any body recognise make and model?
