P
Phil
as the title. I know they are the cheaper end of price but its the link bars inside the boards that make them look so much better inside
Discuss anyone fitted a chint board in the UK Electrical Forum area at ElectriciansForums.net
Never fitted a pre-assembled board but we've tried the MCB's and RCD's on a couple of budget jobs. The screws are prone to stripping when you give them that final 'umph' as you tighten them and we had a couple of internal mechanical failures where the MCB's just refused to reset. I don't think they're complete garbage but I do think it might be worth spending a little extra for something a little more higher-end quality wise
I seem to remember coming across Chint on a job somewhere... Can't remember where though but I've a feeling they're rebadged BG...
the problem with those solid bars is that you can't alter the config. they're not as bad as some make out. i've used a couple. they deffo not BG.
as the title. I know they are the cheaper end of pric but its the link bars inside the boards that make them look so much better inside
must proof readmust
Reply to anyone fitted a chint board in the UK Electrical Forum area at ElectriciansForums.net
