W
wade88
Alright lads,
As brief as i can - Screw auger dosing head, driven by a Carpanelli 0.37KW (1/2 HP) 3 phase 415V 1380max RPM induction motor . Under very little stress, is dosing a material into the feed heads, with a consistency of that of play doh or floury lard - soft and very pliable, can see no reason why a motor of this spec would have a hard time.
However, the auger screw is indexed so the motor will complete a turn say every 0.5 seconds, i know very little about motors, fortunately im off on a course soon to become a little more acquainted. That being said however i understand enough about induction motors to be a little perplexed as to what may have gone wrong. The electrical connections are fine, no loose terminations which may be causing a phase imbalance - so the paired coils should be getting the electricity they need to energise the aluminium rods and turn the rotor. But this is appears to be the issue, when the motor is turned on it would appear there is movement within the motor and the coils are energized, but the screw thread at the end of the rotor is turning inconsistently, sometimes it will complete several turns in a row, other times it will turn once, then stutter or complete half turns.
What may be causing this inconsistency?
Thanks lads
Ben
Thanks lads
Ben
