Il tell you what to type in and you can play apart in pricing this with me , its good to talk so you dont get shot
Discuss Anyone got a good pricing programme? in the Talk Electrician area at ElectriciansForums.net
Ok here goes? 10mm 3c swa x 20m
63a tp-n switch fuse ,40a mcb
8way tp-n board, 10 way dual rcd board
63a 4pole isolater for board. 1 x 4mm t&e
16mm 5c swa 22m , 10 double socket
6 x 32a rcbos , 10 surface mounted double boxes
34 double sockets, 6a mcb
34 fast fix boxes ,3 x twin 5ft em fittings
4 rolls of 4mm t&e, 2g switch and key switch
2x 32a 5 pin isloator& sockets, 2 extaractor fans
2 x 32a 3 ph mcb typec and d, 2 fused spurs
6mm 3c high tuff x 20m, 1x disabled call point kit with strobe
200 x click inceptor 7w 6a mcb x2
200 x click adapters, 1g+1 key switch
7 x 10a rcbo, 3 exit boxes
8g switch plate and back box, 2 emergency surface fittings
1 key switch 6 x 1.5mm t&e
5 x emergeny fittings/surface mounted, 2 x 2.5 t&e
3 x exit boxes, ariel install for freeview
30m of 10mm bonding
32a 5 pin isolator
32a 3 ph breaker
6mm 3c x 20m swa, 4X DISCO 28W FITTINGS WITH EM BACK UP ON 2 OF THEM AND 3 PIR SENSORS
£20 all in, plus an hour with your wife... Well, I am Polish
I used to do Wedding Photography.
The pages inside the album and the size of photo could vary. So I made an excel script that gave me: number of pictures, number of pages (of a style), size of pictures, album cover, add vat, add 20% (for E&OE), then add 50% (my 'salary').
I'm trying to adapt at the moment but there's a lot of variables. Easier if you stick to certain type of kit.
What I'm saying is if I can do it, anyone can.
If I ever get it finished I'll stick it up. All you'll have to do is change the name of the item and the base price, it'll do the rest for you.
I'm omitting the salary bit. This is just for parts.
Reply to Anyone got a good pricing programme? in the Talk Electrician area at ElectriciansForums.net
