- Joined
- Jul 27, 2010
- Messages
- 67
- Reaction score
- 9
Hi guys
Was wondering if anyone had a Robin KT 1610 multi tester that could help me. I just bought one second hand and it doesen't seem to want to test RCD's or the loop impedance of circuits also the live lights at the top don't come on when you plug it in to a known live soure. It will however test insulation and continuity.
I opened up the back and when I took off the outer casing and found a loose cable( red) that seems to have been soldered on to the printed circuit board, it then goes to the fuse holder to complete the circuit. However I can't see where the cable was on the pcb to solder it back on and hopefully fix the problem. If anyone has a tester like this could you please look at yours and possibly let me know or even send me a picture (I can give you my email address) of were it goes on the board?
Hopefully this will be the problem why it's not testing RCD's or the insulation resistance, I don't want to have to put in to get fixed anywhere because it will probably cost more than the tester did.
Thanks. That will teach me to buy second hand :blush5:
