Anyone have experience with Car charging ports? | on ElectriciansForums
Discuss Anyone have experience with Car charging ports? in the Commercial Electrical Advice area at ElectriciansForums.net
Jim90
Norwich
Been tasked to put a quote together for 3 EV chargers. The client wants a super fast charger and seen a few online - Rolec Basic charge to be exact.
The supply is fine, I’ll send out a 6mm 4core SWA.
I can’t seem to find anything on banging in an Earth stake? Im unsure if it’s a necessity.
I’ve put wall mounted kits in before and the Manfacturer specified Earth rods.
I will allow for 3 just Incase. Anyone know more about these things?? If I’m still getting nowhere I’ll call up the manufacturer tomorrow.
A bit extra involved here with notifications and earthing design. Recommend the IET Code of Practice for a read up :) .
Commercial, block of offices. 63A sub main 3 phase DB. Hardly any circuits in it, literally a small lighting circuit and a socket for the mains room.
4 core is for the super fast 32A 3phase version sorry.
I saw the book online, might have to pursuade the boss to buy one!
have been on a course today funnily enough, run by ev-box im approved to install rolec and they are not great quality, the bits inside are made by chint! enough said. rolec themselves dont devlop the tech side and buy off the shelf and sell cheap to flood the market, have installed some rolec units and am not impressed at all.
The ev box stuff is much much better, yes it can be around ÂŁ200 more expensive but it is far superior in quality. Also they have better support than rolec, i will be doing just ev-bov from now on in, i will push them over rolec anyday. i found the rolec uk support quite poor,
I can give you the info for the uk contact guy if you want it? also if you fancy a free days training and free buffet lunch then ev-box are your people.
In terms of earth, if you are 100% sure its tns and not pme at any point back to dno transformer then can use dno's earth. if pme then you can export it to a shed or garage if no extraneous metal parts etc and the car will remain in the garage during charging.
Otherwise whack a rod in, it saves any ambiguity, you may have to put 2 in 3m apart if you cant get the reading. you can utilise the single or dual rods for all chargers. for what you want i would go for the business designed units rather than the rolec ones,
Its all good and well saying a fast charge but if the car is sat at work for 6 hours, why rush the charge? it can charge over the 6 hours as if its done after 2 hours it doesnt achieve anything other than more cost for a higher rated unit. unless there is a time requirement to charge it in say 2 hours, the slightly lower rated charger will achieve the same. if you had a fast charge unit that can charge a car in 2 hours, then why have 3? as it only takes somebody to move to allow the other 2 cars to charge up...
the ev-box people do better units having seen them first hand today.
Ive just done he course also. I believe that it is recommended in the code of practicice you should TT a TNS system also in case the DNO changes the supply in the future.
You need to notify the DNO of the changes via there on line application form. You could ask them if they intend to change there system in the near future, and get them to put it in writing.
There are quite a few other options and requirements, so definately get the code of practice before going any further with this one.
Reply to Anyone have experience with Car charging ports? in the Commercial Electrical Advice area at ElectriciansForums.net
I contacted bp pulse and they needed the serial number before even discussing what might be at fault... When im out at it next, ill take cover...
It should give fairly accurate results. Bear in mind your car will probably have a smart charging system, so worth having a read up on those.
