Anyone know this RCD symbol? | on ElectriciansForums
Discuss Anyone know this RCD symbol? in the UK Electrical Forum area at ElectriciansForums.net
jjjinx
Milton Keynes
Hi guys,
I know the AC symbol but the one to the right i've not seen before or just not noticed it.
Anyone know?
  • [ElectriciansForums.net] Anyone know this RCD symbol?
Hi guys,
Anyone know?
Well spotted. I have no idea.
At a guess, I’d say it's nothing to do with the breaking spec, e.g. pulsed dc, as that would be in the rectangular box with the ac symbol.
Could it be something as simple as Double Pole - i.e. the device breaks the neutral as well as the line? Is this maybe an old device which pre-dates the double switch symbol?
It is nowadays extremely important. Unfortunately, the straight MFT won't test for this. Shark fin is actually a waveform of a pulse which is responsible for nuisance tripping. It is not standardized, however. German vendors will use the capital letter K, with the same meaning. I have a secret tip how to test this: make a circuit on the table being protected with the RCD under test, and apply a Martindale EZ-150 socket tester (any other won't fit!). They apply an 500 usec pulse train. If the RCD won't trip, then it is fine, otherwise avoid it or limit its use. Of course, any other tests must pass, too. There are a lot of RCDs on the market, which may not have the shark fin mark, but withstand those ugly short pulses. It is worth to select RCDs for this feature otherwise the customer may become unsatisfied.
No. It obviously means for use only in rooms with left-hand hung doors.
Serious point though: If an icon can’t be easily understood, it’s badly designed.
I though it was Katie Price from the side,
Reply to Anyone know this RCD symbol? in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, I'm working on an electrical design project and need a library of symbols that comply with the IEEE/ANSI 315-1975 standard for...
Thank you! I didn't realise the wiring was QUITE that old… I'll replace it carefully.
