Came across this board today while looking for a fault on the supply to electric gates. The house is only 2 years old. It was wired by an NICEIC domestic installer. The 32amp MCB's are for ring mains circuits. t 004.jpg
1 - is that 2.5 into the last 32A? - nice
2 - lot of rings and load on the RCCD. hope the diversity calcs have been checked. may just be for convenience but still are they really needed to be 32A then?
3 - better to put larger breakers closer to the origin ie make the 16A the furthest from the RCCD.
Not only is it 100mA but it is S type. This was a split load board. All sockets were on this side. The other side with lights and cooker ect had another S type 100mA. The whole place was a joke. The incoming suply is TT and at the main meter the guy has an 100 amp main switch, come out of it are 2 16mm split cons. 1 goes to the garage which is a run of about 5 meters. In the garage board there is no RCD protection at all. The other split goes on a run about 25 meters to the house. In the house I had a quick look at a few things. Downlights in the kitchen and bathroom have no joint boxes just choc block connectors. The list goes on.
overzealous type S usage and completelly forgot the 30mA requirement seems to be the case. Must be too late seeing as I commented on the 80A but ignored to comment on the more obvious type S and 100mA, cant see the wood for the trees syndrome or just late. good one. customer probably couldnt see a problem with anything on your list just to anoy you saying "but it is new" or something like that.
Customer was very understanding and said he never trusted they guy that wired the house. It was the builder who hired the electrician and he kept assuring the customer it was fine. Customer wants it all put right. Nice to get a good customer for a change.
Most downlighters I see have a terminal strip connected to them but also come with a cover which screws over them to make them enclosed.
Most of the lights I have seen just have a connector block, as jiga says. I have not seen any with covers.
I'll bow you your guys better knowledge. It has been a bit since I've replaced one, and that was only when the missus came home with one and ordered me change it. The thing was working so why change it???
I've used control gear a few times and never had any problems. Thats not true, I was using a 3ph 12 way board and the bloody thing was only 75mm deep. Making it a wee bitty on the tight side. I noticed that board was control gear from the solid neutral conductor, I'd never say that they were worse than proteus. If I'm on a job and I get handed proteus to use, I walk. I point blank refuse. The stuff is utter garbage.
Northern Ireland
Anyone see a problem here?
Australia
Hawk81,
tony mc,
