Type:
Hylec-APL | Motor Control Gear | Contactors - https://www.hylec-apl.com/contactors
Hylec-APL | Motor Control Gear | Thermal Overload Relays - https://www.hylec-apl.com/thermal-overload-relays
Got a project coming up where I need to remotely start about 20 pumps so looking at Hylec as the cost is very low. The setup will only be used for a few weeks, perhaps 100 cycles at most.
Just wondering if they're... 'too cheap'?
The setup will be both the devices above to form a starter for each pump. With the contactor coil switching taken from each to a single PLC control panel. So quite a lot to throw together and don't want to use kit that is cheap to the point it has a significant reliability issue, or like some cheap kit, is just a bit fragile/awkward and slows you down when you have 20 to put into service!
Also suspicious as I see screwfix sells them
