Anyone Work on live D.B | on ElectriciansForums
Discuss Anyone Work on live D.B in the UK Electrical Forum area at ElectriciansForums.net
Steve93
Trainee
Southampton
Does anyone work live? As lately been working a fair bit ofarmoured and circuits into various boards at different jobs but everytime I do it i think to myself ‘f***them if they can’t live without power for 20 mins’ it’s more like factories and commercial places. What does everyone else do? Just crack on get it done? Or arrange a time to come back and power down?
001/2 ,you only live once, if you do It could be your
last mistake .not read the electricity work act!
Yes.
But not without an exceptional reason,not without no other way round it,not without proper tooling,training,provision for the safety of both yourself and others.
Also,and probably more important than the above,ONLY as a result of YOUR assessment of the task,never,ever,as a result of someone else's arrangements/promises/failures.
.....So actually,probably a NO :)
Well yes indeed. So there is a flow chart and the EAWR and the memorandum notes and questions and risk assesments. In certain circumstances yes the board is live but the part I work on is not. So I make sure all criteria are met regards risk assessment and reasonable etc. I work mostly on 3 phase Merlin Gerin boards and they are pretty "safe" with a lot of caveats.
Like don't hold on with two hands, don't lean in and push, pull back the black isolators on the bus bar, gloves even if apt. Although saying that in order to satisfy the flow chart in the memorandum and working live, out of hours is the first choice and will be done where I can't meet the criteria in the flow chart to justify working live.
But then working live is really when you are working on a circuit that is live. Not putting in a new circuit which is dead until you test and commission it so I am not quite sure what you mean when you say working live?
I certainly don't work on live circuits as such unless live testing etc.
Most of the time the board is live. Fortunately most of mine are isobar or KQ type where there is little or no risk of an issue. I draw the line at boards or chambers where the prongs or busbars are live and unprotected (having had a previous issue with a lively piece or swa armour that found its way across the busbars, eeekkk
Some of the preceeding comments,are proof,that it is an important,individual decision,taken after many considerations.
All HSE and regulations aside...generally,your first thoughts are the ones to trust.
If whilst you are inspecting (and you would be doing so) you look and think "mmm,that could be..." That's it! You already know the answer.
I have seen a lot of mishaps,where the above had occurred,and then somebody imagined a way these issues might not happen,and bang.
"We always do this", "The boss says we have to" and "Don't be a drama queen"...are common statements,from lucky heroes.
Be a leader,not a follower - even old sheep,still end up mutton ;)
Yes,on many occasions
Obviously where its easier to work with the power off,its a no brainer
Being brought up when it was almost natural to work live when required,I tend to find the "do a risk assessment" and"do so at your own peril" and similar comments a little uncomfortable
I am an electrician,its my occupation working with electrics,even if you are completely against my attitude,you should still be capable of working live safely and without too much fear
I find the warnings of doom and gloom at odds with the occupation that has been chosen
If working live is so alien to most people,how can a modern spark make himself safe doing so,especially if he "has" to work live and maybe never having experienced the situation when as a new breed in training
Yes, very rare in any shop of factory I've been permitted to turn a board off to connect a new circuit. Personally I feel if due care and diligence is taken it can be done safely
Respect due,but that is one hell of a lot of new circuits connected,with the reason for not isolating,being more important than your safety,on every occasion.
There are industries and situations,some of which i have worked in,where shutting down sections are "forbidden",yet when they go off as a result of any other influence,the world does not end.
In the majority of production environments,it is usually the cost of lost production,or re-setting lines,which over-rides isolation.
It may be the cost of out of hours wages,for sparks working,when isolating not during production hours.
The point i am making,is these above reasons are monetary,and if you agree that working live,carries increased risk,above working dead,then this risk is taken to benefit someone else,financially.
I have worked HV,where everybody accepts these risks beforehand,and the remuneration reflects this.
To undertake work LV,live,as described by the OP,as part and parcel of a normal routine,requires the kind of consideration,i hope my post,prompts.
Depends what it is. It could be that I feel there is a different level of risk doing exactly the same job on two different boards due to what's already there. If I decide the level of risk is too high then it'll have to be done when everything can be powered down.
It’s a difficult one,I’ve worked on Live DB,it’s knowing if it’s ok & possible,even taking & replacing cover can trip rcbo’s accidentally.
It’s when it all goes pear shaped the hassle begins,like BANG...
Reply to Anyone Work on live D.B in the UK Electrical Forum area at ElectriciansForums.net
I went with a partner. We're able to support each other and take time off knowing the other is at the helm. We split all profit 50/50 whether we...
