Apartment complex lights not working or pool pump system. Novice maintenance man | on ElectriciansForums
Discuss Apartment complex lights not working or pool pump system. Novice maintenance man in the DIY Electrical Advice area at ElectriciansForums.net
chris1982
Quartzsite, AZ
Apartment complex lights not working or pool pump system. Novice maintenance man with very little experience in electrical, and my job is on the line
  • [ElectriciansForums.net] Apartment complex lights not working or pool pump system. Novice maintenance man
Call a reputable local electrician
You should not be undertaking work you are not competent at.
Mistakes with electricity can be fatal, especially with pools and poolside equipment.
Your job should never be on the line if you need an expert to safely repair or install something.
I have to agree with @James, just seeing a contactor inside of a junction box pretty much tells us the knowledge of your maintenance. Please hire an actual electrician.
Reply to Apartment complex lights not working or pool pump system. Novice maintenance man in the DIY Electrical Advice area at ElectriciansForums.net
Adding a led strip isn't going to make much difference to the 3 phase balance. No real difference to where a 3 phase machine uses one phase to...
Hi guys I’m at one of the funny times in my career where I can’t decide on what I want to do. I’m wondering if one of you experiences folks can...
