apartments-common areas | on ElectriciansForums
Discuss apartments-common areas in the Australia area at ElectriciansForums.net
davelerave
hey-can someone tell me what's the usual method of lighting control in the common areas of apartment blocks
is it time delay switches-and is there any manual over-ride needed?
you have to be over 45 to know what gregs are. basically ceiling roses that will fit on a standard conduit box with a plug in connector for the fitting. modern ones are made by klik.
Reply to apartments-common areas in the Australia area at ElectriciansForums.net
Hi James, Many thanks for your response and suggestions. The only reservation I have about leaving things as they are and making a contribution...
I know it was a few years ago when LED was mor in its infancy but we looked at a job that had designer flo light fittings in a big bar. The...
