Daveyboy
Hi guys, can anyone point to the building reg about appliances in the kitchen having a seperate switching, e.g washing machine under a worktop- socket under the worktop supplied from fused spur above. Thanks.
Discuss appliances in kitchen having seperate switching eg by fused spur in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
In theory if you had means of isolation for each appliance, you could end up with a lots of switches/FCUs (I know you could have a grid switch). just got me thinking- like for a cooker hood in a kitchen could just have a single socket where the hood will go so you can just plug it in (behind the housing) or would you need a means of isolation elsewhere?
My interpretation of accessible is
I’m going to fall on the side of DP isolators.
Reply to appliances in kitchen having seperate switching eg by fused spur in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
