Thought it might be fun to share some of our more ... uninspiring moments
We upgraded the supply to a sub-board in a factory Monday afternoon, pulled out the old 16mm for 35mm. I had the job of terminating the new cables while the boss hooked up the zappy end. Low and behold, he comes to check my work only to see that I've bolted the Neutral tail to the Earth bar and vice-versa! Felt a right numpty then for sure. Fixed up and all good now though
On a side note, pulling 4x35mm + 16mm Earth through a 50mm conduit = no fun at all.
