Approx re-wire length of time? | on ElectriciansForums
Discuss Approx re-wire length of time? in the UK Electrical Forum area at ElectriciansForums.net
N
Noob2013
Hi all.
I know it all depends on routes, snags etc and you havent seen the property but I'm after an approx length of time (give or take) you would expect this rewire to take for one electrician.
5 bedrooms, lounge, dining room, kitchen, playroom and 3 bathrooms. Also 3 landings to have lights and switches.
All rooms will require all sockets and switches to be chased out with an average of 6 sockets per room and 1 light. Also an aerial point in each room.
Kitchen will have spotlights and electric cooker. No electric showers but extractor fan and shaver point in each bathroom. Couple of outside lights. Supply to fed 2 way C.U in outside store room.
As I said, there are a lot of factors involved so just after a rough idea.
Cheers
I'd have to agree with the three weeks, especially as you said it is and old house - lots of lovely lime render to fall off every time you show it a wall chaser or SDS.
I'd even add a couple more days if you have to make good as well - you'll end up with (on average) half a wall per room to re-render.
I would say the timescale sounds about right, but if it's empty and there is not much else going on in the way of other trades, you might be surprised how quick it goes in.
I'd be surprised if many had experience with cob walls though :S
Hi all.
Cheers
Is that 1 Electrician + a mate/laborer??? because any rewire on your own would be rather difficult.
One electrician and possibly help from a non tradesman for pulling cable
I see you are an Apprentice, and from that I deduce (my middle name is Sherlock, not really) that you may only have limited experience in rewiring a property of this size. You mention possible help from a non tradesman to pull in cables, I assume this would be a mate of yours.
It would be difficult for a non trades person to understand what is required when asked to do this that and the other, you would be spending most of your time explaining what is actually required, not sure of what stage you are in your training, but are you confident in what is required? do you have a mentor for this project? I'm not trying to put you down, honestly, as you can learn from practical experience, personally I wouldn't like to try rewiring a property of that size relying on occasional non technical help.
I completely understand what your saying.
I'm not far off being qualified but will be mentored throughout. I have done a fair bit of chasing but have limited domestic experience.
I'm capable of doing it but won't be speedy gonzalez!
Who will be testing and signing the certificates, I'm sorry mate, but I still think you will be biting off more than can chew.
Reply to Approx re-wire length of time? in the UK Electrical Forum area at ElectriciansForums.net
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
