Aqualisa electric shower, mains water entry point blanking plug plumbing advice | on ElectriciansForums
Discuss Aqualisa electric shower, mains water entry point blanking plug plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Aqualisa electric shower, mains water entry point blanking plug Hello, Im looking for help in tracking down a replacement part for an Aqualisa Energy 10.5 Kw Shower. The bit that has started leaking is the top facing mains entry point- Im using the bottom entry point.
Ive attached a few pics of the part in question. It has the grey sleeve in the centre of which sits the slotted point for extraction.... I cannot seem to source this anywhere so any help will be greatly appreciated.
Thank you
Marty
Aqualisa electric shower, mains water entry point blanking plug to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Aqualisa electric shower, mains water entry point blanking plug plumbing advice in the Plumbers Forums area at ElectriciansForums.net
P
Aqualisa shower drips My aqualisa shower drips when turned off. Reluctant to change the whole cartridge (mechanical Aqualisa Thermostatic...
PaulBr
P
Plastic hot water connection. Which compound to use?? Hi, I have a leak on the hot water inlet of my concealed Aqualisa Gainsborough shower. I...
D.I.Y Pedro
