Looking at that plate it's a spot-welder, i.e it welds by resistive heating not by an arc. Ih 2800A and ED 3.5%, and it's got an electronic timer. If you tried stick welding at 2800A, never mind the machine's duty cycle you would need 96.5% of the time off yourself to recover from the burns!
So if it's a spot welder, it has an electronic impulse timer that dumps a slug of current through the transformer primary for x cycles of the mains, making the weld in one impulse. The timer circuit probably has a regulated power supply that will work on a wide range of input voltages, even if it's not supposed to. The weld current depends on the resistance of the work + cables and the transformer itself, and of course the supply voltage. Turning the timer up would compensate for the low voltage and provide the same heat input to the weld, but less efficiently because the heat has more time to dissipate.
Supplies for spot welders should to go back as far as possible towards the origin without sharing submains etc, otherwise the workshop lights flicker annoyingly when you squeeze the trigger.
