are besa boxes weatherproof? | on ElectriciansForums
Discuss are besa boxes weatherproof? in the Australia area at ElectriciansForums.net
Hi
first post
ie galv BESA box cw swa glands box lid and gasket with joints within suitable for outdoor use?
we've seen it done/ done it but is it ip rated?
if not would it merit a code on PIR
thanks for any replies
Vertically and horizontally mounted,Above ground,Rubber gaskets should suffice,within usage reccomendations,as specified,would advise not to put joints underground,headaches later,fault finding,etc!!!!
Reply to are besa boxes weatherproof? in the Australia area at ElectriciansForums.net
