Are pygmy lamps dimmable? | on ElectriciansForums
Discuss Are pygmy lamps dimmable? in the Australia area at ElectriciansForums.net
ive decided that a pygmy lamp and holder is the best to fit in a show room lounge to light a small feature.
ive 1st fixed it so just have a switched live in place, but after looking at the finished work, seems im pushed for room with out it been on show.
i need it to be dimmable all the way down to virtully nothing, just as a normal candesent lamp!
To me a pygmy lamp is a small SES lamp, it would usually be filament or maybe CFL/LED. What type are you using?
If you're thinking about this type then they are dimmable from 0-100%.
[ElectriciansForums.net] Are pygmy lamps dimmable?
If you dim very low, the colour rendering index will be unpredictable. Usually the lower you dim the warmer the light temperature. This might be a problem in the case of display lighting where you typically want to stay in a range above 5000 Kelvin.
Reply to Are pygmy lamps dimmable? in the Australia area at ElectriciansForums.net
By the looks of it the whole head comes off in one unit, guess it has a driver inside of it. Ive tried to Google the Image i have, one comes up...
