After several years with a sky dish, my parents asked me to do something with their old aerial setup. The aerial, high up on the gable was a perfect perch for the local pigeons to sit and make a mess on their doorstep.
They have a Panasonic tv in the living room, connected with a sky+ box, and a Sanyo in a bedroom... with a wii connected to it.
Ive got one of those ÂŁ15 signal detectors from screwfix. 5 green lights to signify strength.
Took the old aerial down and pulled out the old brown coax from 1987.
I fitted a rather large 'hi gain' aerial in their attic and pointed it at a best guess direction. Signal detector showed a just barely 1 green light - not great. I made up a trailing lead, ran it out the hatch to the bedroom and plugged it into the telly. Autoscan picked up 60 channels, which is pretty good for the region we live in. Pretty happy.
I continued to run new screened coax from the attic down the outside and drilled through into the bedroom and living room.
Job finished... bedroom tv still picking up 60 channels... living room only picking up BBC channels?
I didn't have time today to check the connections, or trying the upstairs tv downstairs and vice versa. I'm pretty sure I read somewhere that the different brands of tv use different tuners, and some are better than others with weak signals. is this true?
I'll try a simple 2 output amplifier and see if that helps.
