Customer has decided to install a 10,000L Diesel storage tank with built in pump & hose at his business warehouse for his trucks.
The Fuel tank is sealed but has an access hatch to a small section that houses the fuel hose and a small motor for the pump that draws around 5Amps, it comes pre-flexed with about 1 metre of ordinary 3core flex.
I plan to lay an SWA from the DB to a rotary isolator away from the tank then behind the tank to a metal conduit end box and come back entry through into the access hatch to connect the flex within the conduit box.
I am just curious, are there any special regulation I need to know while dealing with a fuel container? I've checked in my 7671 Regs but can't find anything, the only concern I can think of is the TNCS earthing system possibly causing issues under fault conditions.
Many Thanks.
Many Thanks.
