Ariston ST80 wall mounted immersion 3kw | on ElectriciansForums
Discuss Ariston ST80 wall mounted immersion 3kw in the Australia area at ElectriciansForums.net
Dartmoor
Morning Chaps,
I had a call to one of these heaters the other day at a dentists surgery. No hot water.
There is a thermostat which sets the water temp and a over temp stat which is manually resetable.
Anyone know where or how to reset the overtemp?? This is only thing i didnt check!!
I looked all over this thing but was unable to see it..
Best to check before I quote the client
All help appreciated
G
Hi ,
Thanks, I already have this it mentions manually resetting the over temp cut out but doesn't say where it is physically located on the base of the enclosure. I'll go back tomorrow and have another look......fresh pair of eyes etc.
Rgds
G
Reply to Ariston ST80 wall mounted immersion 3kw in the Australia area at ElectriciansForums.net
To be honest I am in NC and I’ve always used old blankets to cover all my well and never had a problem. Much simpler and has worked every winter...
