J
JamesBrownLive
Just wondered if anyone has used/owns one of these, and if they are any good?
Adjustable Hole Cutter
Cheers
Cheers
Discuss ARMEG Adjustable Hole cutter... in the Electrical Tools and Products area at ElectriciansForums.net
I did use one once ages ago, I obviously didn't like it as dont have one, I have a lot of the bosch power change so find it easier to grab the one I need and not have to mess around setting that up or worry about nails or screws in the ceiling.
I like the Bosch powerchange holesaws. You can get a 70mm from SF, maybe too small, or a 73mm from Axminster, which surely must be close enough. Axminster seem to do the whole range of sizes from 14mm to 152mm.I've got a couple of powerchange ones too, but need a 72mm which they don't do.
There is also DADE Dust and Debris Eliminator, which is a silicon cowl, which catches and traps the dust and debris whilst allowing the use of hole-saws up to 120mm. In my opinion, this is quicker, easier, and cheaper. It works a treat. Most of us already use hole-saws anyway and this device allows them to be still used whilst catching all the nasties, best of all worlds!.
Reply to ARMEG Adjustable Hole cutter... in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
