J
jimmer
Am i right in thinking it is ok for a PVC 70 degree 4 core 35mm2 swa cable to use its armouring as the cpc on a sub main? I would normally always run a 16mm2 seperate cpc but this has come up in a periodic. It seems to be ok in table 54g, is this gosple or should i be applying the adiabatic equation?
Any help much appreciated
